Replacing the harmonic bal on a 72 base 350. Recieved a new fron a vender and base timing mark was at least 20 to 25 degrees advance fro 8 degrees int from orginal dampner, The engine is good with base at 8 and cam set. was running okay, Repace just because of age. Anyone had this issue? Thankyou
1972 base 350 harmonic bal issues
Tags: None
- Top
The timing mark should be slightly counter clockwise from the keyway slot - iirc on an 8" balancer it's about 1/2 " counter clockwise from the key way - if you projected both out from the center of the crankshaft mounting hub.
Does that make sense?
I have a brand new 8" GM balancer which is 1.25" thick I checked.
IMG_20250919_203849[1].jpgJames A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
