Engine/Transmission/Rear Differential Noise Detector Finder Tool - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1314
    I'm trying to determine where a "humming" sound is coming from in the drivetrain of my 63. The humming occurs upon acceleration and stops upon deceleration. Before I start dismantling either the 4 speed tranny or the 3:36 non-posi-rear end, I'm trying to do as much research as possible. One recommendation I received is to purchase one of these tools and hook it up to both the tranny and rear differential and drive the car so the drivetrain under "load". Has anyone used this noise finder tool on their c2's with any precision and or luck or have any other suggestions? If you have purchased one, can you share the tool information that you used?
  • Mark E.
    • April 1, 1993
    • 4609
    If no response here ask a car dealer or mechanic. I haven't used one but our local Jag Land Rover dealer has. I believe they strap to the chassis and bluetooth connect to an app on a phone.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • David M.
      • September 30, 2004
      • 533
      Is this a fully restored car, survivor car, low mile car? How many miles on the drive train?
      Do you have any drive-train service history? Has the trans, diff, u-joints, trailing arms ever been serviced?
      Take a passenger for a ride-along as they will be able to poke their head behind the seats to give you some indication of the sounds origin.
      Noise on acceleration is generally u-joint, engine, or trans mount.
      Look at the main drive shaft for witness marks indicating contact with something.​
      Split the dictionary:
      Start simple. As you go deeper the following parts will need to be removed anyway...
      Pull the main driveshaft and run the engine gently through the gears. Low RPM nothing above 1500.
      Sound gone? Its likely the drive shaft or the rear suspension. If its not gone its likely the trans or clutch.
      Dont rule out a bad U-Joint. Manipulate the main & half shaft U-joints as you remove them, they should be smooth.
      You can visually see a sloppy failing cup and cross shaft. The rust dust is a dead giveaway.
      You do not need to remove the shafts to see these defects.
      With the driveshaft out check the pinion radial and axial slop.
      Next pull the half shafts, check u joints then check for bearing slop at the diff flanges then at the trailing arm flanges. There will be some lash but shouldn't be excessive.
      Spin the components by hand to feel for bearing brinelling.
      A fancy tool isn't any better than good old fashion spatial awareness... touch-see-hear-smell.
      Trailing arm bearings notoriously fail at 40-60K miles. Especially if they've been in situ for the last 62 years and never been greased...if 63s can be greased? But they will make noise all the time so you may rule this out.
      My money, sight unseen, is on u-joints or mounts.
      • Gerald C.
        • June 30, 1987
        • 1314
        David,
        It's a fully restored car with new U-Joints and a rebuilt tranny. There is probably less than a 1,000 on the car. Even the tranny mount is brand new. The rear differential is an open 3:36 and I had Gary Ramadei look at the internals and we didn't see any excessive wear on the original ring and pinion gears. It's a 300 hp, 4 speed as mentioned. I like your suggestions and I'll try each of them as I go through this research process. The Trailing arms were also rebuilt. The odometer has just over 70,000 miles on it and the engine runs fine.
        Thanks for the feedback.
          • 11698
          Does it occur when revving the engine sitting in one spot? Have you tried that?
          We were fighting a vibration in a 1967 327, and it turned out to be the cogged belts. You would not believe the difference in smoothness by switching to smooth belts.
          Just an example.
          • Gerald C.
            • June 30, 1987
            • 1314
            Just an example.
            No noise at idle sitting in one spot.
              • 11698
              Idle is different than having the engine slowly and/or quickly go to 4000 rpm and see if there is a noise.
              You need to reproduce the acceleration without having the car move.
              • Gerald C.
                • June 30, 1987
                • 1314
                I'll try that. Just another step in the research process.
                • David M.
                  • 533
                  Remember new means almost nothing today.
                  I'd start with another rider to poke their head behind the seats to give you some indication of the sounds origin.
                  Also consider a full restoration means the chances something was overlooked as far as torqued down is plausible.
                  Get it up on a lift and explore.
                  Could be something simple...loose trans mount causing the case to move enough to rub and cause noises?
                  • Gerald C.
                    • June 30, 1987
                    • 1314
                    Thanks David. The car is up on a lift for the winter as I have another project going on. Since it's up there I intend to re-torque all the bolts, etc. underneath.
                    • Robert P.
                      • October 19, 2019
                      • 324
                      Most good shops have what they call chassis ears, clips on to different susp pieces on the 4 corners with feedback coming thru a control panel with 4 channels while you are driving. Back in the day they used cables which where a pain but now they are all wireless
                      Bob
                      • Gerald C.
                        • June 30, 1987
                        • 1314
                        Bob
                        Bob
                        that was my original question on has anyone used these tools to diagnose my issue. Do you have any recommendations on the make and model that are the good ones?
                        Jerry
                        • Gary C.
                          Administrator
                          • October 1, 1982
                          • 17948
                          Jerry,
                          YouTube video review of Steelman "chassis ears" https://www.youtube.com/watch?v=EzlAVOu3aqg
                          Gary
                          NCRS Texas Chapter
                          https://www.ncrstexas.org/
                          • Robert P.
                            • October 19, 2019
                            • 324
                            I had a setup that was from snap-on 15+ years ago , very pricey at the time but was sometimes the only way to find the problem
                            Bob
