C2 engine surge - NCRS Discussion Boards
C2 engine surge
  • Richard E.
    • 252
    C2 engine surge
    I’m seeking troubleshooting tips to solve an apparent engine surging issue on a ‘66 4-spd coupe. I don’t know the engine history, but I expect it is equivalent to a 350 HP-327, with relatively low miles since being rebuilt. The car has a Holley 1850-12 carburetor installed on an aftermarket aluminum intake with a heat spacer under the carb base. The carburetor is very clean and probably not very old (at least mileage wise). It has an electric throttle solenoid to raise the idle for the A/C compressor. The choke is electric. Overall, the engine runs strong, starts very good hot or cold, good acceleration with no stumbling / hesitation or backfire, smooth steady curb idle, etc. The car idles about 800 rpm w/o A/C, about 1k rpm with A/C on.
    The surging (jerking) is most prominent with foot off the gas, letting the car coast in gear. It also occurs at slow speed (in gear) with foot on the gas slightly. In these instances, the car will jerk repeatedly until gas is steadily applied. At cruise speed 30 mph and above the situation is less prominent but slightly noticeable. This happens whether the engine is hot or cold. The choke, A/C solenoid, and throttle mechanism all seem to be operating correctly as best I can tell. The situation is annoying, but the car is drivable. I would appreciate thoughts on the cause and possible remedies. Thanks in advance for taking time to respond.
  • Timothy B.
    • April 30, 1983
    • 5202
    Richard,
    In my opinion if the tune is good the carburetor is too lean in the idle circuit. This surge has been mentioned by many people and with a carburetor without adjustable circuits it's hard to suggest a fix. Some people over on the Corvette Forum mentioned changing the main jets solved the problem but I don't see how because the main jets only effect the main circuit of the carburetor and that's not even at play here.
    • John S.
      • May 4, 2008
      • 427
      I agree with Timothy. I had the same issue with my 72 LT1 after I rebuilt the original carb. Lean on idle circuit. Once readjusted it went away.
      John Seeley
      67 Black/Teal
      300 hp 3 speed coupe
      65 Maroon/Black
      35k mile Fuelie coupe
      • Richard E.
        • 252
        Tim, John,
        Very much appreciate your comments. The carb does have idle adjust screws in the front meter block. Could opening them up a bit help? If the idle screw adjust is not a viable possibility, I may just try a different carb (Holley list 3367, 3370 type for example). I expect the model 1850 has a power valve, could this possibly be wrong number (typically 6.5 as I recall). I'm not an engine expert unfortunately.
        My nephew also has a 1972 LT1 Corvette, possibly I can try his carb when he is not looking!
        Thanks again!
        • Mark E.
          • April 1, 1993
          • 4609
          Richard,
          From your description of the problem, it sounds like the surging/jerking happens during high vacuum conditions (coasting, light load). An engine with too much ignition advance will have symptoms that can be described as jerking or a rolling exhaust.
          Is VAC connected to manifold vacuum? If yes, as a test, disconnect and plug the VAC line and see if the condition improves. If it does, there's too much vacuum advance. Since symptoms occur with the throttle closed, VAC probably isn't the cause if it's connected to ported vacuum.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • David M.
            • September 30, 2004
            • 533
            I seem to remember something about the distributor can cause this problem. Excessive end play if memory serves me. I searched but cant find the thread. Might have been Duke or Joe Lucia.
            Eliminate the simple stuff first.
            -vacuum leak
            -fuel system, psi, filter
            -ignition system including the amount of vac and centrifugal advance the distributor adds on top of the base timing. Where does the centrifugal begin to "come in" and at what RPM.
            -lean spot in the fuel curve. What are the plugs telling you?
            -then check the distributor
            • Justin S.
              • July 3, 2013
              • 305
              Decelerate button?
              • Larry E.
                • 1700
                Richard: My 66 Base engine Coupe had a similar problem. (May not have been as serious as yours)
                I thought that my original carb choke was working Ok BUT discovered that it did not
                open 100% fully when engine was warm. I changed the tension on the "divorced choke
                spring in the manifold) and has worked perfect since. That being said I am unfamiliar
                with your carb and do not know what type of choke that it has. Thanks>Larry
                Larry
                LT1 in a 1LE -- One of 134
                • Richard E.
                  • 252
                  Thanks everyone for the great comments. I’ll start investigating these suggestions to see what ultimately works. Regarding vacuum, I know the distributor vacuum advance is fed from the carburetor base at this time. The carb has a capped off vacuum port on the front metering block (passenger side near top of meter block) which I expect is “ported” vacuum. I will probably check the vacuum situation first as it the easiest to accomplish. I don’t have the tools to get into sophisticated timing checks or fuel air ratios etc. but hopefully this is not necessary. Other than this annoying surge issue the engine runs very strong, I don’t want to mess that up! Thanks again.
                    • 6958
                    Tim, try what Mark says ,plug off the vacuum to dist. And drive the car. Sometimes the vacuum diaf.will be failing causing it to surge.Or maybe just the wrong vacuum advance unit part number.
                    • Timothy B.
                      • April 30, 1983
                      • 5202
                      Richard,
                      When you remove the vacuum advance and plug it for your test, reset the idle and recheck the emulsion screws on the front metering block for best idle. Usually when you take timing out it will require opening the throttle blades more for idle and maybe opening the emulsion screws a little. This will expose more or the transfer slot and provide more fuel and maybe help the surge some.
                      • Richard E.
                        • 252
                        Tim, Thanks for the additional tip, I will watch for the change in idle when I disconnect the vacuum advance and will adjust accordingly. I probably cannot get to working the issue until this weekend, but I will post my results as soon as I can.
                        Again, I appreciate all the help from everyone!
                        • Richard E.
                          • 252
                          I had a brief chance to check the distributor vacuum advance. I disconnected the vacuum line at the distributor and plugged it. I also backed out the meter block idle screws ½ turn each. Engine idle only dropped from about 800 RPM to 725 RPM. The engine had already been warmed up when I did this (the electric choke was operating correctly and the choke plate was full open at this point).
                          Driving the car, I noticed a slight improvement but very slight. I checked the manifold vacuum at idle; it was 19.5” Hg and rock steady. The ported vacuum connection on the carb meter block read 0” Hg as expected and responded correctly with increasing vacuum upon acceleration.
                          Not sure what I’ll try next, possibly physically retard the distributor slightly or connect the distributor to ported vacuum. Maybe time to invest in a timing light with adjustable dial. Additional comments are appreciated
                          • Mark E.
                            • April 1, 1993
                            • 4609
                            Since this happens during no or low load conditions, can you duplicate the issue by slowly increasing/varying RPM in neutral with the car stationary? Try with VAC connected and disconnected.
                            If so, likely causes include a lean condition at certain RPMs, an idle transfer circuit problem (since it happens with slight throttle), bad PCV, vacuum leak (less likely since it idles well) or an ignition advance it doesn't like.
                            Hopefully Edward will weigh in- he's the real mechanic.
                            Mark Edmondson
                            Dallas, Texas
                            Texas Chapter
                            • Timothy B.
                              • April 30, 1983
                              • 5202
                              Richard, How much initial timing does the engine have. Maybe take a big swing at it and reduce it to something like 2-4* and go for a drive to see if it gets any better. If not any improvement the carburetor is lean either by gummed up fuel or calibrations.
                              The factory calibrations for a 600 Holley on our Corvette's is IFR .031 - IAB .070 Many of these over the counter 1850 Holley's have smaller .028 IFR (Idle feed restriction) so that may make a difference. I have come to the conclusion to only try one thing at a time and go back if that does not make the surge better, keep notes of what you did so you don't start second guessing yourself.
                              Is the aftermarket intake manifold a open plenum or duel plane plenum, factory is duel plane.
