Proper routing of #4 plug wire- '70 454 AC - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4607
    How should this plug wire be routed? These two photos look down on the right front of engine showing the exhaust manifold , #2 and #4 plug wires, and the rear AC compressor bracket (compressor missing). 1970 454 AC
    ABOVE: #4 plug wire between engine and AC bracket. Shortest route but plug wire touches exhaust manifold. I think (but not sure) this is the original routing and my fat 8mm cables may be the problem
    BELOW: #4 plug wire routed under and behind AC bracket. More bends but doesn't touch exhaust.
    You do not have permission to view this gallery.
    This gallery has 2 photos.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Mark E.
    • April 1, 1993
    • 4607
    Well, apparently this stumped the Forum (not easy to do!). I decided to route the cable around the rear of the bracket (2nd photo). This keeps it from touching the exhaust and it's not as hard to R&R. I suspect this isn't the original routing but this car isn't set up for judging. And if it was judged, I doubt this would be noticed.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
