Locking exhaust manifold studs on a L89 - NCRS Discussion Boards
  • Joseph W.
    • February 20, 2022
    • 380
    I am in the process of finishing up the build on my 1969 L89 coupe.
    This car has power steering so the stud is the most front spot on the drivers side exhaust manifold.
    the stud part number is 3928905.
    You can not run a 3/8-16 nut on it.
    My question is, will it strip the soft aluminum stud hole in the 842 heads?
    Are these studs a one time use type of thing?
    thanks for any help
    1971 coupe LS5 454/365hp
    1969 coupe L71 427/435hp
    1969 coupe L89 427/435hp
  • Gary B.
    • February 1, 1997
    • 7064
    Joseph,
    In an old post Joe Lucia said “The end stud for cars with power steering was GM #3928905. This stud was 3/8"-16--5/16"-18X 2-5/32". It was discontinued quite some time ago and replaced by GM # 14103124. I do not know the configuration of the new part number.”
    Gary
    • Joseph W.
      • February 20, 2022
      • 380
      Thanks Gary
      I have the correct stud with self locking threads.
      Joe Lucia posted on a 2007 thread about this stud a long time ago, and he asked the OP to take a correct size nut and try and thread it on the stud. You can’t do it because of the self locking threads.
      It’s this self locking feature that eliminates the French locks on the exhaust manifolds.
      My concern is that it will mess up the threads on the 842 aluminum heads when I thread the stud in place.
      It sure feels like it would strip the threads.
      I guess I’m also curious about what’s different with the threads on these studs.
      • Patrick B.
        • August 31, 1985
        • 2009
        I think you are right about being careful with the threads in aluminum. I would run a die on the stud thread and use blue locktite if you think it would loosen up
          • 43272
          Originally posted by Joseph Westbury (68953)
          Thanks Gary
          Joseph-----
          I do not know if the locking thread studs (or bolts) were actually used on big blocks with aluminum heads. However, I am very reluctant to use them with aluminum heads. In that regard, I did not use them on the "ZL-1" engine I built.
          • David M.
            • September 30, 2004
            • 533
            Get yourself some pitch gauges/identifiers and find out what the heads threads are. Then locate the matching fastener.
            Is this double sided fastener with two different thread sizes? Do you have pictures?
            Do not run a tap down the hole. Use a thread "chase." Each time you run a cutting tap down a fixed diameter you are widening thread interference making the fastener less effective at clamping the designed load. A chase just cleans out the mountains n valleys without much if any material removal.
            There are sooo many different thread types. 1/4-20 is a 1/4-20 but you need to consider the pitch angle, valley peek & depth, round vs flat et al. Do a little home work.
            ANSI example https://www.engineersedge.com/screw_threads_chart.htm
            The fasteners and gauges are available at several specialty vendors. If you have an old school hardware store they may be of some help. I'd recommend grade 5. Grade 3 is not enough grade 8 is too much.
            McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
            Use a small amount of Henkel 243 primer-less removable loctite on clean fasteners going into aluminum with a steel fastener.
            Torque according to the softer material...aluminum in your case.
            Never use green or red on this application unless its on as heli-coil.
            • Joseph W.
              • February 20, 2022
              • 380
              Never use green or red on this application unless it’s on as heli-coil.
              The aluminum bolt hole is 3/8-16 and it’s fine. I can run a regular bolt into the hole no problem.
              The pic from CC is what the stud should look like.
              I bought the zinc stud and will black oxide it after I cut it to size.
              • Joseph W.
                • February 20, 2022
                • 380
                IMG_2222.png IMG_2222.png …………..sorry for all the images… trying to get used to the new softwareIMG_2222.png
                • Joseph W.
                  • February 20, 2022
                  • 380
                  Ok, so my fix for this problem was to take the correct stud and tap it to correct the threads. They are no longer self locking.
                  The stud threads in to the aluminum heads with no effort.
                  • David M.
                    • 533
                    Looks good.
