1959 carburetor adjustment (230hp late car) - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12863
    Hi all,
    My 1959 Corvettte 230hp (single 4 barrel carb) stumbles a little bit when I reach 4000+ RPM. I get the impression it is running too lean at these higher RPM's (no backfires occure). Where do I find an easy to use adjustment manual for this particular problem?
    regards,
    Rob.
    Rob.
    NCRS Software Developer
  • Jim L.
    • September 30, 1979
    • 1817
    Rob,
    It would be worth your while to temporarily install a wide band air/fuel gauge and to verify your hunch before making any changes to the carburetion. Such gauges are (relatively) cheap and the information they provide eliminates guesswork.
    Jim
    • Rob M.
      NCRS IT Developer
      • January 1, 2004
      • 12863
      Rob,
      Jim
      I found many of these guages but where and how would I mount the sensor of such a guage?
      Rob.
      • Jim L.
        • 1817
        Innovate Motorsports produces a device which lets you temporarily install an O2 sensor at the tailpipe outlet. I believe their term for this piece is "tailpipe clamp" or maybe "exhaust clamp". It looks like this:
        I use one of these when I calibrate Rochester fuel injection. Installed on my '60, this is what it looks like:
        • David H.
          • June 30, 2001
          • 1559
          Rob,
          Jim
          Jim
          What guage do you use? Seem to range from around $70 to a few hundred.
          Dave
          • Jim L.
            • 1817
            Dave all of the equipment I use is from Innovate Motorsports because I can customize it for the exact data I want to see. This was particularly valuable when I was developing a series of FI modifications to mitigate the FI fuel percolation problem.
            For monitoring only air/fuel ratios, I use the LC2 controller and the DB gauge ( think that's the correct nomenclature). Here is a link to them at Summit Racing:
            Free Shipping - Innovate DB Digital Wideband Air/Fuel Ratio Gauge with LC-2 Kits with qualifying orders of $109. Shop Gauges at Summit Racing.
            The tailpipe clamp I mentioned doesn't have to be used with only Innovate equipment. AFAIK, all O2 sensors have the same threads so the clamp can be used with any other brand of air/fuel gauge.
            Jim
            • David H.
              • June 30, 2001
              • 1559
              Jim
              Jim
              Dave
              PS: Jeff likes doing those "How to do it" things after NorCal zoom meetings. I think you giving an intro Air/Fuel measuring school would be very useful. Just a thought!!
              • Jim L.
                • 1817
                That's an interesting idea, Dave!
                From the questions and answers I've seen which deal with dialing in carburetors by guess and by golly, I agree that many folks could benefit from knowing how to measure actual air/fuel ratios and how to use that information properly.
                Hmmmmm..........................
                • Rob M.
                  NCRS IT Developer
                  • January 1, 2004
                  • 12863
                  Any other directions to fix my stumbling at 4000+ RPM issue???
                  Rob.
                  • Arland D.
                    Moderator
                    • July 31, 1980
                    • 428
                    Rob,
                    You may have already thoroughly checked it out but is there any chance this is an ignition related issue?
                    • Rob M.
                      NCRS IT Developer
                      • January 1, 2004
                      • 12863
                      Originally posted by Arland Dower (3734)
                      Rob,
                      maybe, could be, i'm looking for a good troubleshooting guide...
                      Rob.
                      • Thomas H.
                        • August 31, 2005
                        • 1068
                        Try another coil. Coils can sometimes be the source of a misfire at high RPM's.
                        What's the old saying - many carb issues are ignition issues and most ignition issues are usually carb related.............. Or something like that.
                        2007 Z06, Lemans Blue
                        • Rob M.
                          NCRS IT Developer
                          • January 1, 2004
                          • 12863
                          Good suggestion Thomas, I'll try an alternative coil and see what happens...
                          Rob.
