Front Bumper Brackets - NCRS Discussion Boards
  • James F.
    • March 1, 1997
    • 51
    I'm installing the front bumpers on my '61, The front main & outer brackets pose a problem to me. I slide them together and line up the open bolt hole & the one that's threaded where they meet. At that point, the narrow end
    of the front outer curls up and separates from the front main. The separation is enough to slide your finger in.
    The photos show a piece of foam about 1/2" thick in that space. There is a hole behind the foam that lines up
    with the Main bracket.
    The holes in the outer and main appear to line up. SG 11-5 is not real clear if a bolt goes thru them. If not, why are there holes drilled? My AIM Section page is almost blank. At first I thought the outer was bent at the end,
    not so on 2 different ones.
    Before I get doing what I usually do, put it together and take back apart, I would appreciate what gives here. Thanks, Jim
    IMG_2025-08-11-23-20-30-187.jpg IMG_2025-08-11-23-21-46-872.jpg SG 11-5 Bumper.jpg
  • Thomas H.
    • August 31, 2005
    • 1068
    Looks like the outer bracket may not have been bent properly - or got bent. You should be able to bend it to fit fairly easily with a vise and some muscle.
    I'd mock everything up first without the last bolt to make sure everything else fits - including the bumpers. Then address the last bolt.
    Or if they are new parts, return them for ones that fit.
    Tom
    2007 Z06, Lemans Blue
