1966 Corvette L72 blk/blk Convert (4 Star Bowtie) on Bring a Trailer - NCRS Discussion Boards
  • Daniel S.
    • January 14, 2011
    • 309
    Hi All,
    Does anyone know the current owner of this Corvette? Would like to chat with him.
    Dan
    Bid for the chance to own a 1966 Chevrolet Corvette Convertible L72 427/425 4-Speed at auction with Bring a Trailer, the home of the best vintage and classic cars online. Lot #203,990.
  • Mike M.
    • May 31, 1974
    • 8396
    I'd like to chat with the 66 bowtie team that felt this vet's pad was a factory grind out. mike
    • Daniel S.
      • January 14, 2011
      • 309
      Please elaborate...
      • Harry S.
        • July 31, 2002
        • 5315
        Could be this person..
        • Michael J.
          • January 27, 2009
          • 7128
          1966_chevrolet_corvette-convertible_1966_chevrolet_corvette-convertible_625d7913-e04b-4e04-a01f-125ee680ecc9-NxFqcK-47952-47953-scaled.jpg.webp
          There is an "expert" opinion in an Al Greening certificate there......
          • David H.
            • June 30, 2001
            • 1536
            Mike
            Oh, admit it - didn't that factory grind out explanation bring a smile to your face!
            Dave
            • Sean S.
              • November 1, 1993
              • 91
              Dan,
              Why don’t you try to contact the seller through BAT?
              Seller: djbub.
              He was still chatting with people today, even though the auction has ended.
              Awesome Corvette.
              Hard to beat a triple black big block midyear. Beautiful, blemishes and all.
              Sean
              • Mark F.
                • July 31, 1998
                • 1548
                Was the end plug on the cylinder head installed when the engine assembly code was stamped onto the pad at Tonawanda ?
                When re-grinds at St. Louis were necessary (for whatever reason):
                was the end plug removed ?;
                then the pad ground out ?;
                then the pad restamped ?; and finally
                the end plug reinstalled ?
                thx,
                Mark
                • Mark E.
                  • April 1, 1993
                  • 4581
                  Mike,
                  Thanks for making me chuckle today- needed that.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                    • 15606
                    The Tonawanda assembly stamp was done before the head(s) were installed.
                    If St Louis ground and restamped I very much doubt they removed the head(s) and certainly not the end plug. The story from living St Louis employees was that they did only minor engine repairs and work requiring R&R of intake or heads usually required engine return to the engine assembly plant.
                    • Patrick B.
                      • August 31, 1985
                      • 2000
                      That would have to have been done with the head off. I think they disassembled problem engines and reused the parts. It was probably a bare block when the first stamping was removed. It is not obvious what kind of tool was used to remove the first stamping. It seems like an overly brutal method of removing 0.010 of material. I have seen one 67 block that was reused by the factory where they didn’t bother to remove the first stamping. They simply stamped beside and over it with a later date application.
