F41 shock labels - NCRS Discussion Boards
F41 shock labels
  • Kerry A.
    • August 31, 2004
    • 153
    F41 shock labels
    It seems to me that from memory I read that the front/rear f41 shock labels/stickers have radius corners. Does my memory serve me correctly? Unless I overlooked the information in the TIMJG, radius corners isn’t noted. The stickers on my shocks have radius corners and passed Top Flight judging 3 times. The rear shocks were removed, bushings replaced and repainted. The only stickers that I’m able to find have squared corners. According to Chicago Corvette, there’s a supply issue for the radius corners. Thank you.
    • 11692
    It's not a problem to make radiused corners from a square-cornered label.
      • 11692
      With this:
      https://www.amazon.com/dp/B0076FJ7SS?th=1
      I'm sure that other similar tools exist.
      Having said that, it seems unusual that only the F41 shocks would have rounded corners if made at the same plant - and I don't know that they were - as the standard shocks.
      • Douglas L.
        • August 31, 2003
        • 302
        Kerry - I have 67 coupe with original standard shocks. The shock labels are "radius corners". I did search a long time ago for reproduction labels for another 67 I have and was not successful locating any. Therefore, I gave up looking. That was over 25 years ago.
