1962 Speedometer r & r - NCRS Discussion Boards
  • Richard L.
    • November 1, 1984
    • 206
    The speedometer in my '62 needs to be serviced (very noisy and fluttering) and, after putting it off for several months, I am finally resigned to removing it. Just where do I begin and how to proceed? Does the whole gauge cluster need to come out?
    I'm a small guy (small hands) and will remove the driver's seat for better access, does the steering column also need to be lowered? Any tips, advice and warnings very much appreciated.
    Ric
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Ric,
    Yes the cluster needs to be removed to service the speedometer.
    Your ST-12 has the procedure.
    Online version here...Section 1-6
    Mark each lamp socket for reinstallation reference. Also note the black ground wire attached to one of the gauge mount studs.
    Section 12 has some color codes...
    Rich
    • Richard L.
      • November 1, 1984
      • 206
      Richard,
      thank you, you've confirmed my worst fears. I'll leave the project till this winter when the snow falls.
      • Thomas B.
        Infrequent User
        • April 30, 1997
        • 21
        You might also want to have the tach rebuilt while the cluster is out. D & M Restoration, a Driveline advertiser, rebuilt my tach and speedo 20 years ago; still working well.
        • Richard L.
          • November 1, 1984
          • 206
          Not a bad idea.
