Vacuum advance - NCRS Discussion Boards
Vacuum advance
  • Donald O.
    • May 31, 1990
    • 1593
    Vacuum advance
    I believe that a 1967 L79 (49 state version) uses a B28 vacuum advance but all I can find is a B26 unit.
    Are the B28 units no longer available?
    Is the B28 unit the correct one?
    mine still operates nicely but I’d like to get an insurance one.
    Don
  • T P.
    Infrequent User
    • July 25, 2024
    • 9
    Try Corvette Central for the B28 (#272033).
    In a prior post by Duke Williams, he notes that "the OE L-79 VAC is '236 16" [B28], but it idles at 14"@750rpm; this VAC is too aggressive." So you might want to use a B26 instead.
      • 15706
      The OE 8" VAC is more aggressive than necessary. If your L-79 has an OE equivalent cam idle behavior should be 750 @ 14-15", so a 12" B26 passes the Two-Inch Rule. The NAPA number is VC-1765 and any other parts store should be able to cross that to whatever brand they carry. I'm not sure who actually manufactures these VACs now, but all the major brands should have the same part and be stamped B26.
      There are lots of stories of recently manufactured VACs being out of spec, so I suggest you buy locally and use a vacuum pump to check that the pin starts moving at 6' and is to the limit at 12".
      To change the VAC with the distributor in the car pump it down all the way to expose the forward screw. With the screws removed carefully wiggle the pin out of the breaker plate. Pump down the new VAC and install in the reverse order.
      • Donald O.
        • May 31, 1990
        • 1593
        I’m looking to keep my 67 L79 stock, repeat stock. My only deviation in 40 years of ownership was when I pulled the heads 35 years ago to replace a broken exhaust valve, was to pocket port and a 3 angle valve job. I also used the thin metal head gasket instead of the newer thick ones that are prevalent now. I h save timing set to factory specs, it doesn’t ping and I don’t use racing fuel, just the e10 93 octane here in Sillynois. It’s also not my first time replacing a vacuum advance can either.
          • 15706
          The OE " 8 VAC was stamped MS 236 16, so that's what you need if you want to maintain strict OE visual appearance, but an OE MS 236 16 will likely be hard to find, new or used that's functional.
          So that leaves the aftermakret "B-series" as the common replacements, and the B26 is functionally better that the B28. The VAC is worth 3 points - 2 for originality and once for condition, so at worst any B-series VAC might get a one point deduction.
          Given the lazy OE centrifugal curve and your 93 octane fuel you should be able to run ligher centrifugal springs, and since the max OE centrifugal is 30 degrees you need 6-10 initial to achieve the optimum range of 36-40 total WOT advance.
          You may find the following two threads useful"
          https://www.forums.ncrs.org/forum/te...print-overhaul
          https://www.forums.ncrs.org/forum/te...-to-all-owners
          • James W.
            • December 1, 1990
            • 2676
            Standard Motor Products part number for a B26 distributor vacuum canister is VC-181. I have a few new box in the basement as spares along with lead wires and ground wires.
            • Douglas C.
              • September 30, 1988
              • 249
              Back on April, I purchased two B28 Vacuum Advances from Rockauto. (Wells 4V1053). Both tested good at 8mm Hg on a vacuum pump.
              • Donald O.
                • May 31, 1990
                • 1593
                Don’t you mean 8 inches of vacuum?
                  • 15706
                  Regardless of what he "means" a B28 should provide maximum advance at 8 INCHES of mercury.
                  • Douglas C.
                    • 249
                    Sorry, yes, I meant 8 inches. Spent too many years as an engineer working in the metric system.
                    • Mark E.
                      • April 1, 1993
                      • 4609
                      I would say the US spent too many years working in the English system.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                      • Donald O.
                        • May 31, 1990
                        • 1593
                        Not a problem Douglas. I retired from British engine engineering co. I had to learn to speak British, without an accent of course.
