Faulty Ammeter - 1967 - NCRS Discussion Boards
  • Jeff B.
    • April 30, 1980
    • 169
    Was going to a car show last Saturday. Tried to start car, battery was low and would only click the solenoid and not turn engine over. Connected jumper cables and car started right up. However, noticed the ammeter needle was showing a massive charging rate, where the needle was pointing over to the "+" mark right next to the 40. Figured that was OK since battery was so severely discharged. Headed out to the car show but noticed the needle never started "backing off" as the battery began taking the charge from the alternator. Drove about 30 minutes to the show, and needle never moved at all. Turned car off and needle remained "stuck" at the +40 mark on the gauge. Turning on headlights and restarting engine made no change on the position of the needle. Four hours later, ready to head home and car started just fine, but needle still stuck at +40. Got home, shut engine off and needle still hadn't moved. Took a small rubber hammer and tapped on front of gauge to see if needle might bounce back to 0, but did not move at all. Battery voltage showed about 13 volts, and slightly over 14 with engine running. Has the gauge gone bad, or possibly something else? Have owned this car for 47 years, and hesitate to remove instrument cluster (never been out) to replace gauge. Any thoughts on how to troubleshoot this issue.
    Thanks for any suggestions.
    Jeff
    1967 Coupe 427-390 w/air
  • Stephen L.
    • May 31, 1984
    • 3158
    Disconnect batttery. If meter stays at 40 then the meter is stuck. Probably need to repair/replace meter.
    On cars this old it is a good practice to install a battery disconnect and use it when car is not in use.
    This can prevent a wiring failure/possible fire and save the clock. Clocks "wind" about every 2 minutes or 262800 times per year. Each "wind" shortens the life of the mechanism, eventually causing the clock to no longer work.
    • Mark E.
      • April 1, 1993
      • 4549
      Here's a CF thread describing how to R&R the gauge without removing the cluster:
      https://www.corvetteforum.com/forums...e-cluster.html
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Jeff B.
        • April 30, 1980
        • 169
        Steve:
        Will try disconnect of battery to see. If needle is stuck; any chance it may eventually jar loose and return to 0 (from road vibration) over time from continuing to drive car?
        • Jeff B.
          • April 30, 1980
          • 169
          Mark:
          Very informative article from CF. May have to eventually replace gauge and this thread spells out everything to do. Thanks for the info.
          • Larry M.
            • January 1, 1992
            • 2695
            Jeff:
            You might also be able to "shock" the gage into moving using a AAA 1.5 volt battery. Touch battery posts BRIEFLY to ammeter electrical posts. You can access from engine compartment wiring (orange fusible link wires at horn relay and at starter), or from the electrical bulkhead connector block on firewall, or from back of the gage directly. Just take a bit of time to get the battery polarity correct so you help to reset gage to zero versus pushing it further off-scale.
            Larry
