1966 - 1972 white paint code 972 - DuPont stock code 5040 - NCRS Discussion Boards
  • Kenneth K.
    • September 30, 1992
    • 118
    Hello everyone-
    I need some help in finding the correct shade of CanAm white paint code 972 for my 69 L-71 automatic roadster that is scheduled for body and paint work in November. My painter gave me 2 spray outs of paint code 972 CanAm White from different paint brands and they are not the same shade of white. One is a very clean bright white and the other is an off-white. The car has been sanded down to the original white and primer so I can’t get a match on the body. There is some white paint on the inside of the door panel which I polished but my painter said that when they sprayed the door they don't apply a lot of paint to it and because of that it not going to give me an accurate match. I asked Bob Demmel about this and he suggested I talked to John Bollard who has original paint samples.
    I messaged John and he was kind enough to give me a phone call to discuss my options. Unfortunately all the original paint samples he has he does not have the CanAm white code 972. He suggested I find a small sample of original DuPont with the Stock Code 5040. Use this to make a spray out then match my paint to the spray out. So my first question does anyone have a small sample of original DuPont Stock Code 5040 paint they would sell me or know where to find it?
    Another option would be to find an original spray out of the CanAm white code 972. Does anyone have an original white spray out. I could send you my spray outs and you could tell me which one was the best match.
    Another option is to find someone that painted their car with the white paint code 972 and has the formula they could share with me. Looking thru the Black Book paint code 972 was offered from 1966 thru 1972. I believe all of these paints were also DuPont Stock Code 5040. If this assumption is correct then a paint sample or formula for any of these years would match my 69 CanAm White. Here are the color names by year that are coded 972;
    1966 and 1967 Ermine White
    1968 Polar White
    1969 CanAm White
    1970, 1971 and 1972 Classic White
    Please let me know if anyone has an original paint spray out or a small amount of DuPont Stock Code 5040 paint or has the formula that matches the DuPont Stock Code 5040 they could share with me I would be very grateful. Any other options on how to get the correct shade of white would also be appreciated.
    Ken
  • Jack M.
    • March 1, 1991
    • 1153
    Hi Ken- I sent you a Private Message yesterday, including my contact info.
    I'm not sure if a 1969 GM Color Standard is what you are looking for...
    Itz a metal plate, with the paint color sprayed on the reverse side.
    If so, I've also messaged someone that may have one for sale.
    Perhaps touch base with John Ballard... is this something that may help:
    (uncertain if/how colors are impacted with age and storage)
    • Kenneth K.
      • 118
      Hi Jack-
      Thank you for the PM you sent me yesterday. I am going to send the photo of your metal paint standard to John Ballard to see what he thinks. Your paint standard says it is for a white 1969 Corvette but for some reason it not stock number 5040. There was only one white used in 1969 by DuPont so maybe it’s the same as the 5040.
      Thanks for your help,
      Ken
      • Jack M.
        • March 1, 1991
        • 1153
        Ken- I've often used this website to cross reference paint codes: CLICK HERE
        The Dupont 5040 is mentioned, but I have no clue on the two variations:
        • Kenneth K.
          • 118
          Jack-
          I believe the 5040L is for Lucite and the 5040D is for Delux. I have no idea what the difference is between the two.
          From your cross reference it appears the WA3465 is the GM paint stock number. Why a DuPont paint standard has the GM stock number and not the DuPont number is a question for John. Very confusing when you don’t know anything about paint manufacturing which I don’t 😊.
          Ken
          • Jack M.
            • March 1, 1991
            • 1153
            Ken- My paint IQ is lower than my waist size... so I'm not much help.
            Is the Lucite a lacquer paint, while the Dulux was enamel?
            I see different formulas in an old Acme paint booklet.
            (those codes are likely useless today)
