I had my Holly carb from my 70 LT1 refreshed this winter. All internal parts were replaced. Last week I finally had the time to install the carb and go for my first ride this year. It was a short 20 mile ride and all went well. A couple of days later, I tried to go for another ride but the car started and then died immediately. When I removed the air filter, it was saturated with gas along with the carb. With the carb exposed, I cranked the engine over and gas came shooting out of the front venture tube. I assumed a stuck needle and seat. I removed it, did not see anything wrong, but sprayed it with carb cleaner anyway. Reassembled and had the same problem. When I removed the screw from the side of the bowl, the fuel level was below the screw hole. I had an unopened rebuild kit for another Holly that I have. I put in another new needle and seat from that kit but have the same problem. I also removed the bowl and check the float to be sure that it did not have any gas in it. Any help would be greatly appreciated.
Mel
Mel
