C2 Aluminum Valve Cover Gasket Preferences - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 459
    So far I have looked at the cork valve cover gaskets from Zip (back-ordered) and Corvette Central and those listed by Fel-Pro (5/32 & 7/32). I also called Fel-Pro about their Cork-LAM gaskets # 1604. Has anyone had good/bad results from any of these? Suggestions regarding thickness?
    Thanks in Advance.
    Fred
  • Don H.
    Moderator
    • June 16, 2009
    • 2273
    Suggest standard cork gasket from NAPA.. Permatex to attach it. Cheap and easy.
    • John F.
      • March 23, 2008
      • 2415
      Cork all the way.
        • December 1, 2005
        • 195
        Fred,
        Cork is the way to go. If you wish, go to my TDB post from January 1, 2021 Re: Fel Pro Valve Cover Gasket for background info of how I install the gaskets. I’m sure there are many ways to skin this cat (successfully) but what I have outlined has worked well for me on street cars and race cars. Good luck!
        • Gary B.
          • February 1, 1997
          • 7054
          Fred,
          The Fel-Pro 1604 are literally twice as thick as the standard cork gaskets. They are about 0.313” thick before they are compressed. I tried using the 1604 gaskets along with some Arp valve cover bolts with a reduced hex head so as to not scratch the valve covers with the socket, but the Arp bolts weren’t long enough because the gaskets were so thick. If you have aftermarket rocker arms that are taller than normal, you might want the extra clearance height that the 1604 gasket offers. I went back to the standard thickness composite cork gaskets.
          Gary
          • Frederick H.
            • August 31, 1983
            • 459
            Thanks all - will keep it simple with the cork and some good old Permatex Indian Head Shellac gasket sealer.
