Manifold gaskets - NCRS Discussion Boards
Manifold gaskets
  • Tom W.
    Infrequent User
    • February 29, 2024
    • 4
    Manifold gaskets
    Original sbc engines did not use gaskets between the ex manifold and the head and the Center bolts were tight and the end ones not very tight, hence the locks on them. I believe this was to allow the manifolds to move as they got hot. All was good. Now I am using aluminum heads on my ‘62 corvette with stock manifolds. Do I use gaskets or not? Thanks for any wisdom you may have out there.
  • Mark E.
    • April 1, 1993
    • 4609
    Good question... different head/manifold material with different thermal expansion. I've never done this but two thoughts:
    - Starting in 1986 L98 had aluminum heads. What gasket, if any, did they use? (Can't remember if they used cast iron manifolds.... maybe not).
    - Install the manifolds without gaskets. If they leak, install gaskets you can easily slip in like these:
    Free Shipping - Fel-Pro Exhaust Manifold Gaskets with qualifying orders of $109. Shop Header and Exhaust Manifold Gaskets at Summit Racing.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
