1967 Rally Wheels - NCRS Discussion Boards
1967 Rally Wheels
  • Gary A.
    • May 31, 2001
    • 165
    1967 Rally Wheels
    I have a set of 5 rally wheels with a B stamped next to the valve stem, a KH stamp, and a GM stamp, opposite each other near the bolt holes. I’ve yet to see a date stamp or size stamp. I know 67 is either DG or DC, however I’ve seen in the archives that B may have been used in early 67. My 67 is late May built. Doubtful they are original to my car. Any additional information would be greatly appreciated. Gary
  • Mark F.
    • July 31, 1998
    • 1605
    Gary,
    This article might help explain a few things...
    My wheels for his survey were listed in Wendel's chart under body build date K28 (June 28, 1967)
    hope this helps...
    1967Rally_Wheels.pdf
    thx,
    Mark
    • Gary A.
      • May 31, 2001
      • 165
      Mark; Very informative article. Fills in the blanks. Thanks. Gary
      • Gary A.
        • May 31, 2001
        • 165
        Mark; Thank you again for the information you sent. This morning I found the date 8/66 and the 15x6 JK stamp. All 5 are for the early 67. Not original for my May 67 build but functionally correct. I won’t be having the car judged. Now I’ll be comfortable ordering a set of redlines. Those are correct for my car based on build sheet. Gary
        • Mark F.
          • July 31, 1998
          • 1605
          Good deal, Gary,
          Perhaps as "scarce ?" as the B-stamp '67 Rallys are (you pretty much have to have a September-built car for those) - maybe you could sell what you have and get a set of DCs or DGs ? As the article says, they were also used on other Chevies - although some may have been 14" rather than the 15s for Corvette..
          I'm pretty sure the 3 of mine in Wendel's article were original to my car...can't remember what the other two were ?
          thx,
          Mark
          • Jeff B.
            • April 30, 1980
            • 169
            Gary:
            My 67 was built on Jan 23. Bought it off a used car lot in 1978. All five of my wheels are stamped "DG". Your "B" stamped wheels are quite rare.
            1967 Coupe 427-390 w/air
            • Neal K.
              • October 31, 2007
              • 305
              My 1967 L79 roadster with a production number of 179 and build date of September 1966 has 5 Rally wheels with a B stamp
              • Tim S.
                • May 31, 1990
                • 715
                My Sept. 6th, 1966 build car (VIN 142) has "B's" as well.
