Inner Fender Bonding Strip - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5302
    Need some advice.
    The seller has little detail about this bonding strip. Anyone know what side ( RH or LH ) and it really 63 only?
  • Douglas C.
    • September 30, 1988
    • 230
    Generally, a '63 will have four of these. The flat sides bond to the top of the inner fender, while the "curvy" side butts up against and follows the contours of the top surround. Sealant or " dum-dum" is placed between the curvy side and the top surround. This is a '63 only application . The AIM shows these in Section. 11-13, sheet 6. To me, this appears to be the RH rear strip, but that's a " best guess". Maybe others will chime in on this.
    • Douglas C.
      • 230
      Here's a pic of what might be the same bonding strip. The pic is from an original '63 inner fender that's been in my backyard for over 25 years. RH side, rear facing. You can see where the overflow mount was previously bonded to the lower left.
      • Mike M.
        • May 31, 1974
        • 8385
        harry: appears the ebay seller's bonding strip is missing the inboard 90degree piece.mike
        • Harry S.
          • July 31, 2002
          • 5302
          Mike, Agree with you.
          I need the left side as I need to raise the inner fender.
          Thanks Gents
          • Bob W.
            • December 1, 1977
            • 802
            Harry, The one for sale on e-bay is for the front of the inner fender. The other pic is for the rear of the inner fender.
            • Douglas C.
              • 230
              For what its worth, the reproduction pieces available from the various vendors aren't even close to the originals. I used the reproduction pieces on my '63 convertible, but had to cut them down the spine and re-glass them to match the shape of the original bonding strips. Here's a pic of an original RH front piece... (top surround is largely missing).
              • Harry S.
                • July 31, 2002
                • 5302
                I was able to get under the 63 today. This is the LH front inner fender Bonding strip. Looks like the one on eBay is the right side.
                The search continues!
                • Bob W.
                  • December 1, 1977
                  • 802
                  Harry, sent you a pm hope it went through . let me know here.
                  • Harry S.
                    • July 31, 2002
                    • 5302
                    Bob, got it ..... Thanks
