Air filter for fuel injection - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 827
    I can't find a filter for my 63. What are others doing for a replacement filter?
  • Dan H.
    • July 31, 1977
    • 1372
    Bob, I use a FVP P 6418 which will need a spacer to hold it all the way forward in the housing. I used a piece of heater hose to take up the gap. Air flow is much better than the old foam ones and it won't crumble either.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Michael J.
      • January 27, 2009
      • 7173
      This is the one I use, it fits perfectly.....
      https://www.napaonline.com/en/p/FIL6418
      • Alan D.
        • January 1, 2005
        • 2054
        OK, here is some information I've saved over the years Air Filter for C2 FI.docx
        Note sure how the attachment will work, first time trying and have not had any luck with any attachements
        or pictures on the new site. (does not appear to open, wants you to down load???)
        SOooo if you want I can type it into response if cut/paste works?? Just tried on new response - no Paste function
        Send email to akayconsultants@hotmail.com and I will send you a copy
          • 15706
          This filter has several dozen applications - motorhomes, Ford pickup trucks including MD and HD, Mustang..., so it should be around for awhile and is likely relatively low restriction like no more than a few inches H20 at the maximum air flow demand of a 327 FI engine.
          Here's an interesting story about a "rare" filter, the fuel filter for the Cosworth Vega. It's almost the size of an oil filter and has an internal bypass valve. I couldn't believe that such filter would be scratch designed and manufactured for such a low volume application (3508 jobs built for the '75 and '76 model years), and research in some OLD parts books showed that it was originally designed as the transmission filter for the GM 6-71 diesel powered "old look" city transit bus two speed torque converter transmission that I rode on in the 1950s as a kid in Seattle. Maybe some of you did too.
          I had a real loose converter and from a standstill the engine would almost immediately hit the 1800 RPM governor and the bus would accelerate. At about 25 MPH the driver would lift off the throttle, you'd hear/feel a "clunk" and it would drop in to second, and it felt like the converter locked up. Max speed at 1800 was about 45-50 MPH.
          Bendix was the supplier of the Cosworth Vega's EFI system including this filter, and I managed to get a hold of the right Bendix people and found they had enough parts left over to build about 50 of them. This was in the late 90s, and it was discontinued from GMPD. Bendix agreed to build 50 or how ever many they had parts for at a decent unit price, so I organized a parts program through the Cosworth Vega Owners' Association. Members prepaid through the club for however many they wanted, and when it sold out the club sent a check to Bendix and everyone got their filters. I bought three, and the club bought a few for later sale to members who needed one.
          I could be that the '63-'65 FI filter existed when Chevrolet chose it or maybe it was actually a new design that was picked up by other manufacturers.
          P. S. So which NAPA filter is the best fit? 6416 or 6418?
          • Bob H.
            • July 31, 2000
            • 827
            Thanks to all of you!!! I am over my headache!
              • 15706
              This thread has recommend two different NAPA air filters, similar appearance, but different dimensions.
              So can anyone answer my previous question: Which one is the best fit, 6416 or 6418?
              • Michael J.
                • January 27, 2009
                • 7173
                The NAPA filter I linked to fits perfect in my FI units, 1963 and 1964. There was no reason for me to look at any alternative. The 6416 is shorter and not as wide, so I suspect it is too loose and needs something to make it fit.
