!966 Rear Lighting Harness - NCRS Discussion Boards
  • Walter R.
    • January 6, 2009
    • 271
    I am putting parts back on afer paint which started 3 years ago so some things are a little lost in my memory. The rear lighting harness which I replaced 10 years ago has two harness clips for fastening harness in place. The hole in the clips is about 5/16 but I cannot determine what they would attach to. Secondly, where does the ground wire for the license plate light atttach?
  • Leif A.
    • August 31, 1997
    • 3645
    Walter,
    The clips go over the inboard tail lights. The ground wire is attached under the driver's side nut holding the license plate lamp assembly in place.
    Leif
