73 Rear Window Install - NCRS Discussion Boards
  • David C.
    • January 23, 2024
    • 44
    I bought a correct tinted and date coded rear window for my 73 coupe. I intend to have a professional glass installer install it. I'm worried that they'll install it in a way that won't pass NCRS muster. Do I need to source some weatherstrip material ahead of time? Any advice?
    73 Coupe, L-48, auto, Body Build Date: 31 May 1973
    Member - Southern Nevada Chapter NCRS
  • Russ S.
    • April 30, 1982
    • 2162
    It uses ribbon black butyl tape which your installer should have on hand. Install so that the date and LOF read from inside of the car.
    • David C.
      • January 23, 2024
      • 44
      Thanks, Russ. I've since found that Zip sells an installation kit with butyl tape and some other bits, including instructions. I may try it myself if the instruction are clear.
      • Keith W.
        • May 25, 2018
        • 201
        Has anyone tried something similar with a plastic convertible window? Is there a way to remove the plastic window to work on yellow staining and scratches? I have already removed about 95% of the scratches from mine but the yellowing really didn’t change much. I have heard there is a hydrogen peroxide mix that can be used but no way will I try that with the window still in the top. I’m too afraid of discoloring the black top.
        I hope it was ok to piggyback on this thread. If not, I apologize.
        Good luck David!
