Hello everyone, my 70 came with a Carter Carburetor, and it worked fine until recently, when I noticed it was leaking fuel at the fuel inlet fitting.
After speaking with several people, they said that the long-thread repair fitting, nor the helicoil repair procedure would work on a Carter, because supposedly the metal around that fitting is soft and thin.
So, for safety reasons I decided to replace it with a rebuilt Rochester carb. A trusted mechanic friend of mine put in the Rochester and it doesn't seem to "want" to idle. It's fine at about 1300-1400 rpms, but dies when you try to slow it down.
Vacuum measurements seems fine, and we can't figure it out. Any suggestions? Thanks
