74 Caliper Casting Number Confusion - NCRS Discussion Boards
  • Victor S.
    • August 24, 2017
    • 89
    Hello All -
    73-74 judging guide states the 74 model caliper casting numbers are: 5452281 (inner rear), 5452284 (outer rear), 5452270 (inner front) and 5452273 (outer front).
    However, other published GM references state the above casting numbers as 67-71 and lists 72-82 calipers as:
    5473806 (inner rear), 5473807 (outer rear)
    5473795 (inner front) and 5473796 (outer front)
    Can someone verify which set of casting numbers are correct for the 74 model?
    Thank you,
    Vic
    • 43287
    Originally posted by Victor Scherer (63906)
    Hello All -
    Thank you,
    Vic
    Vic------
    In my long-held opinion, 1974 used the 547xxxx caliper casting numbers. In my opinion, if the 545xxxx calipers are found on a 1974 they most likely got there as sleeved, rebuilt EXCHANGE calipers.
    • David B.
      • March 1, 1980
      • 691
      The caliper build date is stamped on the lower side of one of the caliper outboard ears. The build date is either a four or five digit number.
      • Victor S.
        • August 24, 2017
        • 89
        Thanks Guys - All my originals (that looked like they had never been off my 74) were the 547's that Joe referenced - but there is conflicting info out there for sure.
        Many thanks for your help.
        Vic
