‘66 windshield washer pump replace/rebuild suggestions - NCRS Discussion Boards
  • Wayne L.
    • January 27, 2023
    • 40
    I
    My windshield washers do not work. I can hear the motor clicking when I activate the switch. I’ve tried to prime the pump with fluid with no luck. This Vette sat in storage for decades before I acquired it so I assume it’s an issue with the pump’s rubber diaphragm but haven’t taken it apart to inspect the internal components. I’m looking for suggestions on rebuilding or replacing the pump. If I go down the “rebuilding path” which kits are the best?
    Originality is paramount as my ‘66 Corvette is an unrestored car and I missed a “Top Flight” award by a cat whisker first time out so as long as I’m correcting the functionality of the pump, I want to make sure I keep the pump visually 100% correct per original factory appearance.
    any suggestions would be appreciated.
  • Don H.
    Moderator
    • June 16, 2009
    • 2282
    Steve Hackel. No one is better, or has faster turnaround.. Midlothian IL.
    ​​​​​http://restorationservice.net/
    • Larry E.
      • 1700
      Wayne: Don't assume it is the pump. Let's check the "Low Hanging Fruit" first. My
      66 Coupe did the same thing and it turned out to be the hoses that attached to the Nozzles.. Also check your
      nozzles that might be blocked. Search this board as this has been discussed many
      times. You will get more idea's. Larry
      Larry
      LT1 in a 1LE -- One of 134
      • Dave B.
        • August 31, 2024
        • 54
        I fixed my inop '66 pump using the correct cheap rebuild kit from Zip. It includes a diaphragm but I didn't need it. My problem was just the gasket behind the white plastic hose connection plate on the pump. My car had been sitting about 10 years.
