I replaced the windshield in my '67 coupe with a new one from Classic Auto Glass. My old windshield was scratched and also leaked water into the cabin.
Regrettably, although the new windshield is beautiful, I am still getting water inside the car!
Whoever installed the old windshield used black urethane to glue down the surround moudings! My installer had to use a razor to carefully cut the urethane to release the moldings, then remove the old windshield. The paint did lift in a couple of small areas, which with the moldings back in place aren't too noticeable. The installer used a new gasket from "Corvette Rubber" and was careful to use caulk/sealer in all the right places, but alas, water still finds its way in! I was present during the installation, and the windshield channel looked good, with no obvious reason why the new windshield would leak once installed.
My installer has done C2 windshields before, and warned me that leaks are hard to fix and are common on C2's. Why is this?
On mine, the water drips on the outer (door) ends of the footwells. The passenger side is leakier than the driver's side.
I'm reluctant to remove the windshield again, disturbing everything in an possibly futile effort to fix the leaks.
One form of adaptation is to devise a means to catch the water that comes in. I don't drive the car in the rain, although it does get washed, and rain can happen during a drive.
My question is: Has anyone devised a means to catch water coming into the cabin? I put small trays on the floor when I wash the car, but that's not practicable to do during a drive.
Any suggestions?
Any suggestions?
- vB Messenger Page
 C2 coupe leaking windshield - rain catcher ideas?
