73 Repro Trim Ring Fitment - NCRS Discussion Boards
  • David C.
    • January 23, 2024
    • 47
    I bought a set of repro 4-clip trim rings (made in Taiwan) for my 73 with brand new rallye wheels. The tire shop that installed the wheels gave up on trying to install the trims, so I got the car home and tried it myself. With two people (my wife's a trouper), a large screw driver and a mallet I manged to get the third clip attached, but I don't see how the fourth one can go on without something breaking. BTW, these were purchased from Zip.
    Has anyone had success with these trim rings? Are they known to not fit?
    73 Coupe, L-48, auto, Body Build Date: 31 May 1973
    Member - Southern Nevada Chapter NCRS
  • Steven B.
    • June 30, 1982
    • 4000
    David, was this the case with all four wheels? Might want to contact ZIP to see if they have encountered this before. Good Luck! Steve
      • 11666
      Will they fit on an original GM wheel?
      I have seen problems with reproduction rally wheels not being to spec.
      • David C.
        • January 23, 2024
        • 47
        Well I never thought they'd get that wrong, but it turns out they did. My repro wheels are about a quarter inch smaller in diameter than my original spare. Thanks!
          • 11666
          Yup.
          Just find some real ones and give them a new coat of paint if needed.
          You and your car will be much happier.
            • 15616
            Yup.
            As one of my favorite people used to say "Ain't that special."
            • David C.
              • January 23, 2024
              • 47
              A final note to close out the topic. My original spare wheel has a diameter of about 16 3/8 inches. The repro wheel has a diameter of about 16 1/8 inches. That quarter inch is enough to keep the trim rings from fitting.
