283 220 hp pcv - NCRS Discussion Boards
283 220 hp pcv
  • Douglas C.
    • August 31, 1990
    • 384
    283 220 hp pcv
    Question, is correct PCV cv590c or cv609c.
    And is there a cross reference for a non nos replacement.
    Tks. DRC
    • 15672
    I can't answer your question directly, but if you have an original '61 283/220 that was sold new in California it would had to have the RPO that included a PCV system. I cannot find the number in my old NCRS Spec Guide, but 242 is stuck in my head. Check the AIM, and here's a thread that might help. I just found it with a Web search - "RPO 242".
    https://www.corvetteforum.com/forums...pcv-valve.html
      • 43221
      Tks. DRC
      Douglas-----
      The original PCV valve for your application was GM #5646366, aka AC CV-276. It was discontinued in March, 1966 and replaced by GM #6421787, aka AC 695C. The latter was discontinued without supercession in May, 1981. I know of no current aftermarket valve for the application but it is possible that one exists.
      The CV-590C was used on 1963 Corvettes and is the same general configuration as the above-referenced (i.e. threaded on one end and a nipple on the other end) but I have no idea if it would be a correct functional replacement. GM strongly implies it would not (since it was never supercessive to the original). The CV-609C is a different configuration (differing size nipples on either end) .
      • Douglas C.
        • August 31, 1990
        • 384
        Thanks guys. As I can find NOS both 590C and 609C on Ebay but I prefer the 590C threaded connection to back of carburetor I'll use 590C.
        Although not exactly correct at least it's an original factory component with proper function.
        Tks. Doug
          • 43221
          Tks. Doug
          Doug------
          Why don't you get this valve on eBay? This is the valve that replaced the original valve as I mentioned in my last post. Plus, it's reasonably priced. Don't pay any attention to the fact that it mentions some non-Chevrolet applications. It's the part number that counts and it has a part number that GM says is right for you.
          • Gary B.
            • February 1, 1997
            • 7020
            Doug,
            Or if you’re dead set on the original valve, then I think this is the original part for 3x the cost of what Joe recommended:
            eBay item number:405017378624
            Gary
            • Douglas C.
              • August 31, 1990
              • 384
              Doug------
              https://www.ebay.com/itm/27541950070...3ABFBMyqqNwr5l
              Thanks. Good information I was not aware of.
              Doug
                • 43221
                I finally dug these out. The CV 276 is the original valve. The CV 695C is the replacement which is also now long-since discontinued as I previously described. [none for sale]
