‘70 Convertible Deck Lid Height - NCRS Discussion Boards
  • Keith W.
    • May 25, 2018
    • 202
    When I open or close the convertible top I have to hold the deck lid up to allow the convertible top to either go down or up to close it. It is a really tight fit. Is there a way to have the deck lid open more? Some kind of adjustment?
  • Stephen B.
    • April 1, 1988
    • 876
    Maybe you need to adjust the springs for the deck lid to hold up more.
    • Keith W.
      • May 25, 2018
      • 202
      Any suggestions on how to do that? If I knew or had instructions on how to do that I would.
      • Russ S.
        • April 30, 1982
        • 2163
        There is no adjustment of the springs or hinges and I don't understand exactly what it is you are saying, however if it is the rear of the deck lid that needs to be raised, install a flat washer between the deck lid and the hinge at the rear bolt.
        • Stephen B.
          • April 1, 1988
          • 876
          I believe there's multiple positions on the springs where they hook onto the part of the hinge assembly. You move the springs to a tighter tension detent.
