There is no specification for the fast idle speed of a cold started fuel injected engine. During ops check it is inappropriate to deduct for a cold FI engine which doesn't idle "fast enough".
I mention this because I've been contacted by a fuelie owner who is worried about this and wanted me to walk him through how to speed up the idle on his engine when cold. Apparently he's had some problems in the past during ops check.
The only specification for FI fast idle is for a fully warmed up engine. (See the charts below.) Prior to the engine being fully warmed, the idle speed can and will be pretty much anything less than the specified hot engine fast idle speed.
So if fast idle speed is to be verified, do this: Warm up the engine thoroughly. Crack the throttle while manually rotating and holding the fast idle cam into position. Release the throttle and measure the engine RPM.
Here are excerpts from ST-12 and the '63 shop manual:
