Yellowing of the plastic convertible window - NCRS Discussion Boards
  • Keith W.
    • May 25, 2018
    • 204
    I want to address the yellow staining on my ‘70 C3 plastic convertible window. Is the staining mainly or entirely on the exterior side of the window? Or, does the yellowing get into the thickness of the window including the interior of the window?
    The exterior will be easy to try to reverse and clean up the yellowing. The interior will be another story as there isn’t much room to physically get in the car and attempt to work on the interior side of the plastic window.
    Any suggestions would be much appreciated!
  • Mark F.
    • July 31, 1998
    • 1622
    Keith,
    type the words as follows in the advanced search window and you will see many threads about the topic you've mentioned:
    yellowing and convertible
    thx,
    Mark
    • Alan D.
      • January 1, 2005
      • 2054
      If you need to do the inside - remove top from car. Just remember to mark locations
      • Donald O.
        • May 31, 1990
        • 1593
        Open the top and lay it over the frames. You can then be outside the car while working on the inside of the rear window.
        Now if I could figure out a way to fold the windshield over to clean its inside, this old body would appreciate that.
