Who relines old brake shoes? - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    Good morning, I have an old Chevy, not corvette...sorry, '54 3/4 ton truck I'm restoring. Brakes shoes are no longer made for these so I was wondering if anyone knows who re-lines brake shoes still. Preferably on long Island NY, would like to stay local. Thanks!
  • Tim S.
    • May 31, 1990
    • 711
    Here you go.......
      • 43247
      Tom-----
      Are you sure that brake shoes are no longer manufactured for your application?
      • Tom L.
        • October 17, 2006
        • 1439
        Well Joe, seems the major vendors for this type of vehicle don't sell a replacement, only very expensive re-lining services. I've looked at some on line general parts vendors and they dont SEEM to be available but perhaps you can do your magic. Like you, seems odd that GM would abandon and re-design something that works. My shoes have plenty of material left in terms of thickness but they are cracked and crumbling.
        It's a 1954 Chevy 3600 (3/4 ton). Rear drums are 12" diameter and they are 2" in width. If more info helps please let me know. Thanks!
        • John P.
          • January 1, 2006
          • 163
          Hello Tom, A friend of mine purchased brake shoes and components from " Chevs of the 40's" last year. His truck is also a 3/4 ton. I installed the front brakes, and they were quality shoes. You can also try "Lutty's Chevrolet Warehouse" in Saxonburg Pa. Hopefully one of these vendors can help. John
          • Gary B.
            • February 1, 1997
            • 7053
            Tom,
            Try this link for brake shoes sold by “Chevy’s of the 40’s”.
            Gary
              • 43247
              Tom-----
              I think that brake shoes are currently available but my expertise does not include much about early 50's Chevrolet trucks (or, even later Chevrolet trucks). But, no need to even look. NOS brake shoes are available and for reasonable prices. I show that your application uses the same shoes front and rear. Here are the part numbers, each supercessive to the former, to look for on eBay and any of these will work:
              GM #3703512 (the original shoes)
              GM #3703513
              GM #3848106
              GM #3933972
              GM #3964529
              GM #1 1 1 5 4 1 2 6
              The last of these was discontinued without supercession in February, 1989.
              • Tom L.
                • October 17, 2006
                • 1439
                Thanks guys. Honestly I'm not crazy about 35+ year old shoes. the ones on the truck have enough material on them to be considered close to new but they are cracked in many places and crumbling on one shoe. I've been looking into this a lot and am finding mixed info. I'm not in a huge rush and since this is a non-corvette issue I'll stay on the sidelines until I can update. Thanks again!
                • Dan L.
                  • November 10, 2008
                  • 81
                  NAPA has brake shoes listed for your application, front and rear.
                  DAN
                  • Steven B.
                    • June 30, 1982
                    • 4000
                    Go with that feeling Tom! I worked in friction production for awhile, brake linings and clutches. (an asbestos plant ) Daily we ran shear and burst tests among others. We tested freshly mixed and cured lining of the day plus various aged samples. Those that were cracked or crumbled were immediately tagged and destroyed as the failure rate was very high. Those imperfections indicated an issue with the component ratio, usually not enough cashew oil or other liquid. Additionally for 35 year old bonded lining the lining has "dried out" and adhesive has likely deteriorated to the point it will release the lining from the shoe. Since the lining is 35+ years old it is likely the lining is composed mainly of asbestos. Good Luck! Steve
                    • John F.
                      • March 23, 2008
                      • 2415
                      Have you looked at the Rock Auto website. They appear to have them.
                      • Chris S.
                        • January 1, 2000
                        • 1068
                        White Post Restorations does re lining and does an excellent job
                        I have personally used them several times
                        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
                        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
                        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
                        1957 Corvette - FI 3 sp - Black and Silver
                        • Tom L.
                          • October 17, 2006
                          • 1439
                          The Napa search seems to be thourough enough to ID the part. I also found that strangely the rear shoes for a '54 GMC were listed on many searches of various parts dealers. I just didn't use Napa because there isn't one that close by. i also noted that there is a FMSI number associated with the GMC shoe, S310. I think napa just changes the S fo FT to make it their own part munber and kept the 310 piece for ID purposes.
                          What I did figure out after I removed the front and rear shoes was that the only difference was the lever for the parking brake. It's bolted on and doesn't come with the shoes like more modern rear brake shoes. I think that's the reason that it doesn't come up on most searches. It's not an "Exact replacement" based on todays standards since the lever isn't there. After all the truck is 71 years old.
                          Anyway, problem solved, thanks again for the input.
