66 Steering Column Question - NCRS Discussion Boards
  • Rob M.
    • April 30, 2003
    • 657
    All,
    I was hoping to get some clarification on the installation of my standard '66 column. I would appreciate some help with following questions:
    -First, the new upper bearing appears to be pre-lubed. Do I need to add any additional grease prior to install? I wouldn't think so, but want to check.
    -Second, what is the best way to measure the lower spring clamp "axial movement of .010-.030 of the steering clamp" to ensure that's done correctly?
    Thanks in advance
