Intake Manifold Getting Hot? - NCRS Discussion Boards
  • Scott V.
    • 42
    Hi,
    My friends 1959 intake manifold has developed a hot spot which has actually burned the paint off (please see picture). Is there a passage that could be blocked. Would appreciate any advice on what this is and how to fix it.
    Scott
  • Gary C.
    Administrator
    • October 1, 1982
    • 17952
    Scott,
    Maybe install manifold heat blockers. See attached 1956 TSB.
    Also, you might want to wire your exhaust heat riser open.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Arland D.
      Moderator
      • July 31, 1980
      • 430
      Once upon a time Dennis Clark and I did this to my 67 Buick 340 engine and it became very cold blooded and took a long time to warm up and run like it should. During the summer it was good for driving in high heat and heavy traffic with the A/C on.
      • Don H.
        • December 1, 1981
        • 1498
        I would consider that normal.
          • 15706
          Check the heat riser valve with the engine cold. Light force on the weight should cause it to rotate down. For normal summer driving I recommend you wire it open.
          I tried blocking the heat riser on my SWC's 327/340 back in the seventies... figured I didn't need it in California and had no intention of ever driving it in "winter conditions" again.
          Driveabiluty was TERRIBLE! The engine had to be running for at least 20-30 minutes before the horrible stumble on clutch release went away unless I slipped the clutch excessively. The CR trans and 3.08 axle was certainly no help.
          I cut shims out of, IIRC, .010" thick 304 stainless steel sheet stock. Since I wasn't sure blocking the heat riser would work out well I bent the top ends over about 90 degrees so I could pull them out if I had to. I recall I drove the car maybe three times from a cold start, and just couldn't stand it, so I loosened the manifold bolts and was able to pull the shims out with needle nose pliers, re-torqued the manifold bolts, and it sealed up.
          It's a good idea to block the heat risers on a dedicated race car, but makes a carbureted engine very cold-blooded.
          I know the WCFB and AFB carbs on 250 and 300 HP 327s have a phenolic spacer that acts as an insulatior... don't know if 283s have such, but check your AIM. Even if such was not OE, consider installing the one from the WCFB-equipped 327/250. I considered using the 327/300 insulator on my 327/340 (was not OE on the 340), but then I would have had to fab new a new choke tube and fuel pipe to the carb and I wasn't sure there was enough hood clearance to I tabled the idea and just dealt with the occasional fuel percolation problems.
            • 43286
            Originally posted by Gary Chesnut (5895)
            Scott,
            Gary
            Gary-----
            If the intake manifold exhaust cross-over passage is blocked, the heat riser valve MUST be wired open or otherwise eliminated.
            • Scott V.
              • 42
              Thanks everyone for the responses. We'll start by checking the heat riser.
