I am completing the restoration of a 1967 big block. I have gone through my wiring harnesses and have had success with all of the rear lights, including the brake and tail lights, license, lamp light, rear compartment, and reverse lights.
On the interior of the car I have dash lights, clock function and light, lighter, blower motor, glove box light, parking brake lamp, bright lights lamp signal (red), flashers work in rear
1. I do not have the lights when the doors open down by the fresh air vents, but rear compartment light comes on
The car turns over. I have not started it yet.
2. No horns but can hear a click at the horn relay
3. Only the bright lights come on the right side with no lights anywhere on low beam. I have put two different dimmer switches in with the same results.
4. No parking lamps. Lamps do not flash when hazards are on and do not blink or light when turn signal is on.
I have replaced the turn signal switch
My head light buckets function well. Was getting flashing of headlights (red) when I had brights on and buckets down on the dash.
Need help with listed items above. I think I am missing something such as a ground. I do have a ground connected to the core support. I am restoring the car and have painted the core support. I did not remove paint when I connected the ground. Because I have power to the headlight motors I assumed the ground was functioning correctly. Again, I have power to headlight motors and lights on one side. I know there are separate grounds on the headlight motors. I am not sure if the ground at the core support comes into play with the headlight motors?
Thanks for any advice. I do have a 12 volt tester and can check for things if someone has a solution.
