63 Front license mount - NCRS Discussion Boards
  • Todd L.
    • November 25, 2020
    • 298
    Can someone tell me if this is correct for 63? Also, it seems odd there is only a flange on one side. Is this correct or has someone modified this? It does have the "ds" on the back side .
  • John F.
    • March 23, 2008
    • 2419
    Yes it is.
    • Don H.
      Moderator
      • June 16, 2009
      • 2282
      Todd
      I can't tell if yours is the 63-65 version or not, but for sure it has been modified. The square holes in corners should be 5/16" and not 3/8". and there should only be one hole in top middle that matches bottom middle, and both sides should have raised flange.
      Here is real 63-65 bracket.
      • Todd L.
        • November 25, 2020
        • 298
        Thank you so much, Don! I will go on the hunt for a correct one.
