1956 Body Drop - NCRS Discussion Boards
1956 Body Drop
  • Sheldon S.
    • March 1, 1999
    • 481
    1956 Body Drop
    I am ready to drop the body on the frame and looking for any tips before starting. I have the column in and will remove the generator for clearance for steering box, Radiator support is in and will install rad afterwards. Fan shroud is in right now but wondering if I should remove for body install. All ideas greatly appreciated.
    Sheldon
  • Mark S.
    • July 31, 1983
    • 664
    Go slowly! Is your distributor and floor linkage out? these are two things that sometimes get pinched, if left in. It is helpful to have another set of eyes watching where things line up.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17940
      Sheldon,
      Wrap the steering column to protect it. Make sure all of the body cushions are in correctly placed where the old ones were. And follow Mark's suggestions to remove distributor, linkage, etc. anything that protrudes.
      Good luck!
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Rod K.
        • 445
        You'll probably have to remove the steering arm from the box, mine hit the oil pan getting it past the frame. Also, I'd remove the fan shroud just to ensure it doesn't get damaged by body motion.
        • David H.
          • June 30, 2001
          • 1559
          Sheldon
          Have you tried a test lift of body off your dolly?
          A test lift will indicate if you need to weight trunk etc to approximately level body.
          Use of wheel dollys may make it easier to position your frame.
          Someone to keep an eye on transmission shift lever as body is dropped.
          Dave
          • Chris S.
            • January 1, 2000
            • 1068
            Brace the body
            The rear of the bodies are heavy and will sag
            I install braces to prevent any sagging
            - Tip on wheel dollies are a must
            No need to remove the distributor
            Column will slide into place
            Have 1 shim and 1 metal shim taped down and the 2 rear rubber mounts at the back in place
            Have your spare time foam on the frame - I glue it in place for the spare tire hole
            Long awls are helpful to line up body holes.
            Several helpers.
            Have your shims in place on the core support
            Have your e brake cable in place - in the body
            mount your speedo cable to the trans if it is a powerglide - it is TIGHT!!!
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
            • Roger W.
              • January 29, 2008
              • 572
              Chris. That is a nice reinforcement in the doo opening. Did you fabricate it? It looks like you are attaching to the door hinges.
              • Chris S.
                • January 1, 2000
                • 1068
                I did fab it up
                It bolts to both the upper and lower hinge - all 6 bolts
                Then to lock pillar
                I place a thick piece of rubber material between the paint and the lock
                Once on the frame - I unbolt the brace
