Thomas-----
The original stop screw would definitely be long enough even with the sleeve. However, this is an odd configuration screw and there might not be enough threads for it once the master cylinder was sleeved. However, the correct size hole could be drilled through the sleeve and threaded, if necessary. I think rebuilders want to avoid all this effort.
