427 390HP or tri-power ground wire attached to.distributor cover '67 TIM&JG, p126-127 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2139
    Looking for an image, part source or better description of the 427 390HP ground wire attached to.distributor cover (description on page 126 of 1967 TIM&JG 8th ed.)
    Or if different, the same ground wire attached to.distributor cover for "tri-power" '67 TIM&JG. The description(s) in 8th edition start on page 126... continues on top of page 127.
    It seems to me only one attaching point is mentioned, that being the riveted end on the distributor surround shield...
    Thanks!
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Stephen L.
    • May 31, 1984
    • 3162
    Are you talking about the grounding strap that is riveted to the front side of the distributor shield. This strap has "serrated" edges, is about 1/2" wide, that contacts the rear of the aircleaner base. IMHO there is no ground WIRE involved. These straps are carried by most vendors.
    • Tom D.
      • 2139
      Yes, thank you Steve.
      Michigan Chapter
      Tom Dingman
