Side Exhaust Rear Frame Mounting Hardware. - NCRS Discussion Boards
  • Thomas S.
    • February 7, 2016
    • 618
    I’m replacing the side exhaust on my (427/400 N14) with the correct GM pipes and hardware. It is a triple crown car but like many others, still had some incorrect components. Mine had an after market SS version, incorrect hardware and a heat-riser with the counterweight sheared off.
    According to the AIM, the rear mounting should consist of a carriage bolt, a large flat washer with a central tower (3863850), two bushings, and another flat washer (3863851). A nut, small flat washer and lock washer completes the assembly.
    I have P/N 3863850, both rubber bushings, and what I thought was the remaining large flat washer P/N 3863861. However, that washer also has a short tower (see picture) which when used in conjunction with the above parts, prevents the entire assembly from closing enough to hold the support bracket on the side pipe. In other words the gap is too large.
    My guess is that I have the wrong bottom washer - can someone confirm?
    By the way - great improvement to the TDB!
    67 427/400 Lynndale Blue Corvette https://online.flippingbook.com/view/750924569
  • Leif A.
    • August 31, 1997
    • 3650
    Thomas,
    I've neve seen anything but a large flat washer for the bottom washer. The one you show is a very interesting washer. Note in the picture below, all the associated hardware for mounting the rear of the side exhaust including the large flat washer.
    Leif
    • Thomas S.
      • February 7, 2016
      • 618
      Agree 100%. The unknown washers were on the car when I purchased it in last year. Lots of thing incorrect despite numerous awards over the years including a Top Flight in 2023 / May.
      One side did not even use the correct washer with the spacing tower and the to rubber bushing was against the frame. Since the unknown washer was odd and on both sides I just assume it was specific for this purpose.
      thanks for the reply.
      Tom
      This interactive flipbook is created with FlippingBook, a service for streaming PDFs online. No download, no waiting. Open and start reading right away!
      67 Lynndale Blue Corvette
