bolt on knock off wheel studs - NCRS Discussion Boards
  • Richard S.
    Infrequent User
    • August 31, 1991
    • 3
    The knock off wheel studs are supposed to be longer that the regular wheel studs Does anyone know who sells these as they are longer than the regular wheel studs This is on a 65 with bolt on wheels
    Richard Schmid
  • Leif A.
    • August 31, 1997
    • 3645
    Re: bolt on knock off wheel studs
    Richard,
    Give America's Finest Corvette (CorvetteUSA) a call. https://www.corvetteusa.com/
    Leif
    • Richard S.
      Infrequent User
      • August 31, 1991
      • 3
      Thanks I sent them a message
      • Joseph S.
        National Judging Chairman
        • March 1, 1985
        • 886
        I'm wondering where you got this information from. There should be no difference in the wheel studs from steel wheels to Knock off wheels. There is a difference in stud length from drum brakes to disc brakes.
        • James W.
          • December 1, 1990
          • 2668
          Or perhaps you are referring to the knock-off wheel adapter lug nuts? They are in fact longer than the standard wheel lug nuts. Just trying to help.
          Happy Holidays,
          James
          • Dave B.
            • August 31, 2024
            • 54
            Richard Schmid
            not the studs, the NUTS.
            Dave
            Rocky Mountain Chapter
            '66 Coupe L72 Laguna Blue/Black
            • Richard S.
              Infrequent User
              • August 31, 1991
              • 3
              The nuts are longer but the studs are supposed to be longer also
              • Joseph S.
                • March 1, 1985
                • 886
                There is no difference in the studs. The only reason that the nuts are longer is so the wheel is installed correctly onto the adapter. If you used regular nuts you could possibly clock the wheel incorrectly and destroy is.
                This whole nut/stud conversation is not an issue if you are using bolt on wheels. Since there is no adapter to attach, the bolt on wheels are supplied with regular lug nuts.
