Zerex G05 Coolant - NCRS Discussion Boards
Zerex G05 Coolant
  • Mike M.
    • December 20, 2013
    • 33
    Hey Joe,
    If you would, please let us know what you did to solve this situation. I had a slow leak on a water pump on my L36 and just replaced the pump. I have never been big on using gasket sealer but this may be a good time to consider using some.
      • 15706
      Originally posted by Joseph Santamaria (50893)
      Re: Zerex G05 Coolant
      Honestly no. It is possible I applied too much pressure on a cold system. I think the system s designed for a 15psi.
      Fifteen psi is the maximum operating pressure assuming a properly functioning 15 psi relief cap, but test pressure should be higher. A radiator shop that rebuilt a radiator for me about 15 years ago said they tested the job to 30 psi.
      For an on the car test I would limit pressure to not much more that 15 psi otherwise hoses could blow.
      Think in terms of a submarine. Say normal operating max depth is 900 feet, EWO might be 1200 and crush depth is 1500.
      • Joseph S.
        • October 27, 2014
        • 192
        #18
        Originally posted by Mike McFarland (59330)
        Hey Joe,
        Sure will Mike- still working it.
        Joe
