When Did Broach Marks Stop? - NCRS Discussion Boards
  • Jeff B.
    • November 6, 2008
    • 166
    I assume that at some point, the factory stopped decking the blocks with the machine that left the classis broach marks parallel to the engine block. I'm not exactly sure what followed, maybe a rotary decking method or CNC, and a different process for aluminum blocks, but I'm wondering if there is a definitive year when the classic broach marks no longer appeared on the block.
  • Mark F.
    • July 31, 1998
    • 1572
    Re: When Did Broach Marks Stop?
    Jeff,
    I'll be interested in responses to this post.
    Granted, my experience in engine plants (where broaching and deck finishing operations - whatever they were and are today - take place) is ancient, but I was not aware broaching machines had been replaced...cast iron or aluminum.
    Is there something else you know about this that makes you assume this machining process was ceased - and/or additional info/background you can add on your post regarding your assumption ?
    thx,
    Mark
    • Jeff B.
      • November 6, 2008
      • 166
      In 1997 all Corvettes got aluminum blocks, and those don’t get decked the same way. But I have no information about the engines just before that. My experience is mostly in C2s which of course were all broached. And I know at least the early C3 were, but I was wondering how long this continued…all the way to 1996? What about C4s ?
      • Mark F.
        • July 31, 1998
        • 1572
        Thank you, Jeff
        Your post prompted me to search the web a bit and I learned a few things...
        This is one link I found interesting...
        "Combining Milling and Broaching for Aluminum Engine Components"
        I've been in aluminum foundries, but have never seen how the block and other engine parts that need to be perfectly FLAT were made to be just that...
        None of this answers your specific question, but more searching may yield a result.
        thx,
        Mark
        • Pete B.
          • February 22, 2007
          • 325
          C4 steel blocks have broach marks.<br />
          Early C5's were vin stamped on a cast aluminum surface.<br />
          Mid C5's through 2010 and probably beyond were stamped or Lazer etched on a flat milled surface on the left rear side of the block.
          Pete Bergmann
          2005 - 2013 C6 National Teamleader
          • Mark F.
            • July 31, 1998
            • 1572
            Thanks, Pete,
            I learn something new everyday on this TDB !
            Excellent topic for a virtual school if somebody has all the knowledge to put it all together...
            Proven by the posts above, I know I don't have the knowledge
            thx,
            Mark
            • Kenneth B.
              • August 31, 1984
              • 2091
              If the cases are machined like other castings now days they would be machined in one or 2 operations & would probably on one or two fixtures.With the CNC'S there is no need for multiple fixtures & different machines. This is why tolerances are so much tighter than in the day
              • Michael J.
                • January 27, 2009
                • 7145
                Yes, as I was watching my 2012 ZR1 built, I saw the guy laser etching the VIN into the block.
                • Michael J.
                  • January 27, 2009
                  • 7145
                  1965-chevrolet-impala-ss-409 (3).jpgI am wondering also when they started, not being a C1 person. I know Tonawanda milled the blocks of the 409s they made in the early '60s, swirled marks on the pad. But later, the 427 BBs were broached.
                  • Jeff B.
                    • November 6, 2008
                    • 166
                    • Ed D.
                      • December 1, 1990
                      • 329
                      If it weren't for the stamp pads, would we be interested in broach marks?
                      Ed DiNapoli
                      CNJ Chapter Past Chairman/Co Founder
                      1972 Targa Blue Coupe, Original Owner,
                      Duntov Award, Sam Foltz Award,
                      Founders Award, NCRS Gallery VIII
                      2011 Corvette Convertible
                      NCRS Presidents Award 2014
                      • Mark F.
                        • July 31, 1998
                        • 1572
                        My guess is no.
                        Just as we aren't interested in the engine plant cylinder honing station marks - because you can't see them...
                        thx,
                        Mark
                        • Jeff B.
                          • November 6, 2008
                          • 166
                          Probably not Ed, but there ARE stamp pads! And I do think understanding manufacturing methods and why they were used (and eventually replaced) has some interesting aspects. GM had no intention of leaving broach marks for the purpose of identifying original engines 60 years later, they were just decking the blocks with the most efficient method they had. The difference in the way we manufacturer automobiles now and just 50 years ago is remarkable.
                          • Steven B.
                            • June 30, 1982
                            • 4000
                            and the 1969 aluminum blocks, how were they done?
                            • Ed D.
                              • December 1, 1990
                              • 329
                              My rhetorical question, was meant to to bring attention to all the rhetoric about broach marks thru the years, that made these marks so important to judging corvette engines. There have been tutorial and miss information regarding how the broach machine machined the block and how deep and what direction the marks were made. With all the new material, new placement of the vin numbers, and the bar coding system, this all disappears.
                              Ed
                              Ed DiNapoli
