C1 Soft Top Removal - NCRS Discussion Boards
C1 Soft Top Removal
  • Jason P.
    • April 6, 2023
    • 207
    C1 Soft Top Removal
    Still working on my 58 Corvette full restoration. I am wanting to take the soft top apart so I can properly restore and paint it. It currently has a very old, possibly original, soft top that is extremely stiff.
    Would it but worth it to try and preserve the top if it was original? Its not in very good shape that I can tell.
    I am pretty sure I should eventually install a new top but wanted to know if there were any tips on how to remove a very old top. Should I just cut it out with scissors?
    Jason
  • Mark S.
    • July 31, 1983
    • 664
    Re: C1 Soft Top Removal
    There are screws through the weatherstrip pieces and small screws through the metal rods. Take those out and pry out the fasteners in the tacking strips. With these out you can peel away the glued fabric and pads. Save everything that you take apart for reference and take pictures. Bag and tag. If your top is original, note the date and stamping on the back window. Al Knoch makes a good replacement top and has a video for installation. You might need new weatherstrips, screws, pads etc. I am sure that others will chime in with their perspectives. Mark
    • Jason P.
      • April 6, 2023
      • 207
      Thanks so much for the info.
      • Mark S.
        • July 31, 1983
        • 664
        You are very welcome!
