'73 Smog Pump Lower Bracket - NCRS Discussion Boards
  • David C.
    • January 23, 2024
    • 47
    I have two lower brackets available for my A.I.R. system restoration. They both have the correct part number and both have "GM" castings. On the orange one the part number is on the edge of the long leg, and on the gray one the part number is on the flat area as shown. Is only one of these correct for a 73?
    73 Coupe, L-48, auto, Body Build Date: 31 May 1973
    Member - Southern Nevada Chapter NCRS
  • Jimmy P.
    • June 24, 2014
    • 1696
    Re: '73 Smog Pump Lower Bracket
    David,
    I’ll go out on a limb here and say either one would be fine for your ‘73. The one I have on my ‘73 is the same as your silver example. The same bracket was used pretty much from around 1966 on. Both examples are fairly common, although your orange example seems more prevalent on earlier pumps that I see for sale. I never really paid that much attention to the difference before now, just looked for GM and the part number.
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
    • John S.
      • June 15, 2015
      • 507
      1973 L82 M21 4 Speed, very original and well documented driver/survivor
      NW Chapter Member, 2016 Bend Regional Top Flight
      73/74 TIM&JG 3rd Edition Revision Team Member
