Engine ID Question - NCRS Discussion Boards
Engine ID Question
  • Mike M.
    • July 24, 2011
    • 297
    Engine ID Question
    This 283 engine may have come out of a Corvette. The numbers look like this:
    Part # 3756519
    Casting Date C558
    Letters on passenger side head: T309D
    thanks for any help on IDing this engine.
    Mike Martin .
  • Jim D.
    • 2884
    Re: Engine ID Question
    It's from a 1958 pass. car or truck.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17747
      Mike,
      Casting Date C558 is a Tonawanda engine, not Flint.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Mike M.
        • July 24, 2011
        • 297
        Originally posted by Gary Chesnut (5895)
        Mike,
        Gary
        Flint engines were the Corvette engines. Right?
        Mike
        • Leif A.
          • August 31, 1997
          • 3636
          Engine block cast March 5, 1958
          Engine assembled at Tonawanda March 9, 1958
          D - Alpha designator
          58 - year used
          283 - cubic inches
          170 - horsepower
          2B - carburetor
          PG - powerglide transission
          PA - passenger car
          Not, a Corvette engine
          Leif
          • Owen L.
            • September 30, 1991
            • 880
            Mike
            Yes, all small block Corvettes got their engines from Flint (coded F or V); all big block Corvettes got their engines from Tonawanda (coded T). There was no mixing of engine plants for big or small blocks. Other model lines also used these two plants (plus others).
            As an aside for the true experts, why did Flint change from the F to V?
              • 11653
              One caveat -
              There are Tonawanda CAST blocks that were then made into Flint ASSEMBLED engines and used on Corvettes.
              Why they took blocks from Tonawanda and shipped them to Flint to be assembled is unknown. But, there are documented original engines made in this fashion.
              • Gary C.
                Administrator
                • October 1, 1982
                • 17747
                Patrick,
                What years and cubic inch were the Towanda blocked shipped to Flint and assembled?
                Gary
                NCRS Texas Chapter
                • Robert B.
                  • March 1, 1992
                  • 265
                  I heard that was the case, I have a 57 fuel car that the Previous owner made a strip car he gave me a correct date code tonawanda block and the fuel unit.He swears its the original block. When you say documentation is out there, where would I find it. thanks
                  • Gary C.
                    Administrator
                    • October 1, 1982
                    • 17747
                    In 1967 F became Flint Motor Facility & Flint Engine plant was changed to V.
                    According to Corvette by the Numbers, no Corvette engines were produced at the Flint Motor Facility.
                    Gary
                    NCRS Texas Chapter
                    • Harry S.
                      • July 31, 2002
                      • 5321
                      As I recall the Tonawanda small blocks were used in the 1965 model year. Maybe KC will chime in.
                      • Gary C.
                        Administrator
                        • October 1, 1982
                        • 17747
                        Robert,
                        Sorry, but there were no Towanda engines used in 1957 Corvettes, ever.
                        Lots of documentation that supports that. Books by Noland Adams, Ken Kayser, Alan Colvin, etc. etc.
                        Gary
                        NCRS Texas Chapter
                          • 11653
                          Patrick,
                          Gary
                          At least 1965 and 1972.
                            • 15606
                            I have seen Flint assembled Tonawanda cast Small blocks in 1969, 1970, 1972 and 1974 Corvettes. I suspect this practice was more common than most will admit.
                            • Joe R.
                              • July 31, 1976
                              • 4551
                              To answer your question. This block did not come out of a Corvette. OR it could have been a replacement block put in a Corvette. It was not put in the Corvette at St. louis. But there are people that make it look like it came in a 1958 Corvette by milling the block and stamping the correct numbers on the right side of the block. Good luck!
                              JR
