Front Bumper Misalignment Question - NCRS Discussion Boards
  • Charles P.
    • November 1, 2021
    • 37
    With many C2s you see that the front bumpers are misaligned and not parallel to the ground; the bumper ends are above the center. I assume these are reproduction replacements. Why are so many misaligned? Are the bumpers themselves not accurate reproductions? Are the mounting brackets not accurate? A replacement front clip with misaligned mounting holes? Or is it just poor installation? Just curious...
  • Bill M.
    • 1328
    Re: Front Bumper Misalignment Question
    I have owned mid years for 45 years and the bumpers always have looked out of wack
    • Leif A.
      • August 31, 1997
      • 3642
      There was a recent post of a C2 coming down the assembly line with the front bumpers crooked...they came that way from the factory. If they were straight, you were lucky.
      Leif
      • Robert B.
        • March 1, 1992
        • 265
        combination of all those things. It some cases it a matter of making a lot of adjustments
        • Charles P.
          • November 1, 2021
          • 37
          Thanks for the info! I guess I am lucky, mine are straight...
          • Charles P.
            • November 1, 2021
            • 37
            Thanks for the post!
            • Thomas B.
              • October 11, 2021
              • 299
              • Ron L.
                • July 31, 1998
                • 111
                Recently installed after-market bumpers and the horizontal brace attached to the frame on my 64. In order to get my bumpers aligned horizontally, and without stress at bolt holes, I had to auger out a majority of the holes and slots with a carbide grinding bit. BUT - do not auger out the holes on the frame, as those are starting points. And, obviously, the holes backed by a welded bolt cannot and should not be messed with. However, all other holes/slots can be modified to get things to go together. Put everything together loosely, don't tighten, until it please you. There is a good video on Youtube of a guy restoring a 63 coupe, and he has a segment on installing bumpers. The same could be used for adjusting. I watched it several times and got some good tips. Finally, don't think this might be a 2 hour job. For the novice, which I am, it took me multiple times of installing, modifying, and reinstalling the pieces before I was satisfied. Good luck.
