1963 small block oil pan gasket set - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1311
    Any recommendations on the best ones to use?
  • Dave S.
    • August 31, 1992
    • 2930
    Re: 1963 small block oil pan gasket set
    Gerry,
    Just be aware that service replacement oil pans use a different gasket set than original oil pans. The front rubber gasket is thicker on the service pans.
    • Leif A.
      • August 31, 1997
      • 3653
      Gerald,
      The "best ones" are a FelPro one piece...
      Leif
      • Owen L.
        • September 30, 1991
        • 891
        Originally posted by Leif Anderson (29632)
        Gerald,
        I like the one-piece, but just be aware that longer bolts may be required because of the thicker gasket. This one looks like it has the bolts with it, so hopefully they are the correct length to get the pan mounted.
        Just an aside: I still used RTV in the corners to add some extra sealing assurance.
        • Harry S.
          • July 31, 2002
          • 5344
          Some folks like the original cork, metal and rubber.
          I like the Mahle one piece. It's black instead of blue. Look at the second picture, it give you the Mahle PN depending on your oil pan. If you are not sure what you have, measure the front opening.
            • 43277
            [ATTACH=CONFIG]124369[/ATTACH]
            [ATTACH=CONFIG]124370[/ATTACH]
            [ATTACH=CONFIG]124371[/ATTACH]
            [ATTACH=CONFIG]124372[/ATTACH]
            [ATTACH=CONFIG]124373[/ATTACH]
            Harry------
            The original PRODUCTION and SERVICE oil pan gaskets had no metal core; they were just cork. Later GM PRODUCTION and SERVICE gaskets, such as the one you pictured, do have a metal core.
            • Harry S.
              • July 31, 2002
              • 5344
              Joe, agree.
                • 11692
                Harry,
                Any idea if this one accepts paint any better than the blue Fel-Pro?
                The material used with the F-P is such that I never have success getting paint to stick to it for long, and the blue color is then very obvious.
                • Harry S.
                  • July 31, 2002
                  • 5344
                  Patrick, I have not tried paint as the cars are no longer judged.
                    • 43277
                    Harry,
                    Patrick-----
                    I doubt that there will be any difference in regards to paint adhesion. They are both silicone rubber and therein lies the problem.
                    • James W.
                      • December 1, 1990
                      • 2673
                      Harry and or Patrick,
                      I assume this for the standard, 5-quart 63-74 oil pan? Do they both require the longer bolts for installation?
                      James
                      • Leif A.
                        • August 31, 1997
                        • 3653
                        James
                        I used my stock oil pan bolts when I installed the FelPro one-piece gasket.
                        Leif
                        • Harry S.
                          • July 31, 2002
                          • 5344
                          James
                          I used the stock bolts, just start in the corners.
