C1 master cylinder ? - NCRS Discussion Boards
  • Brian W.
    • September 30, 1990
    • 216
    I have a master cylinder I believe to be for a C1.
    On the outboard side:
    DELCO
    MORAINE PRODUCTS DIV
    DAYTON O USA
    On the inboard side:
    small #'s: 5450 large #'s 233
    1" DIA Looks like a date stamp 3-8
    End Plug: 545480 320-G These are stamped.
    Cap:
    USE GMC BRAKE FLUID Stamped in the center of the bolt head part W over 32
    Can anyone identify this Master Cylinder?
  • Mike E.
    • February 28, 1975
    • 5153
    • Gary C.
      Administrator
      • October 1, 1982
      • 17971
      Re: C1 master cylinder ?
      Brian,
      IIRC on original master cylinders 5450233 were all the same size.
      Master cylinders with large 233 were service replacements.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Scott S.
        • March 1, 1979
        • 747
        Gary, Thank you.
        Scott
        • Rick G.
          • March 1, 1983
          • 276
          [QUOTE=Gary Chesnut (5895);955276]Brian,
          Gary,
          According to the 5th Edition of the Corvette Technical Information Manual and Judging Guide, "Beginning about January 1959, the master cylinder's casting number has the last three numbers ("022") in larger digits". In my experience I have found this to be correct thru 1962 production.
          Rick
          • Gary C.
            Administrator
            • October 1, 1982
            • 17971
            Rick,
            5450233 was 1956 and may have been installed on early1957 models until inventory was depleted up to approximately 1957 VIN 1500.
            Last three digits in the casting numbers 233 and 022 are same size as all other digits (not larger, as in later master cylinder castings).
            Gary
            NCRS Texas Chapter
            • Rick G.
              • March 1, 1983
              • 276
              Gary,
              My mistake I read the casting number initially as 022.
              Rick
