Removing a stubborn brake drum - NCRS Discussion Boards
  • Bob A.
    • June 30, 1999
    • 38
    Hi All,
    I have a 63 roadster, 98Pt. car. In checking the brakes yesterday, I noticed that one of the studs was stripped and I could not remove the front, right brake drum to check the brakes. I wacked it with a heavy rubber mallet to no avail.
    Any guidance on how to remove a stubborn brake drum is appreciated.
    Additionally, any watchouts for replacing a stripped stud is much appreciated. If replacing one, should I replace all five?
    Bob
    #32465
  • Bill M.
    • 1322
    Re: Removing a stubborn brake drum
    Try heating up the stud area of the drum with a propane torch. Us a sledge hammer and hit while heating. It is probably rusted on atoned the bearing ares.
    • Bob A.
      • June 30, 1999
      • 38
      Thx Bill, Is it better to hit the drum on the front, sides, or rim with the sledge to avoid any issues? Bob
      • Gary C.
        Administrator
        • October 1, 1982
        • 17657
        Bob,
        Step # 1 - back off the brake shoes to make sure they're not binding against the drum
        Gary
        NCRS Texas Chapter
        https://www.ncrstexas.org/
          • 11643
          This works like a charm. Bought it for the same issue on a 63 a few years ago:
          https://www.amazon.com/gp/product/B01JBIU7F4
          • Owen L.
            • September 30, 1991
            • 868
            Originally posted by Gary Chesnut (5895)
            Bob,
            Gary
            Yes, this. If the shoes have worn a groove into the drum they won't let the drum slide off without a lot of force, risking damage to components.
            • Dan H.
              • July 31, 1977
              • 1369
              If it has self adjusters, backing off will be a big problem.
              1964 Red FI Coupe, DUNTOV '09
              • Chris D.
                • November 1, 2002
                • 198
                I second the puller approch after backing off the adjusters. Be aware of replacement stud dimensions. Many have longer splines for later Model years that engage with a thicker hub flange. After putting in all new studs I had a dickens of a time pulling my drums until I realized the splines were extended into the drum web.
                • Bill M.
                  • 1322
                  Hit the outer rim of the drum closest to the wheel. Sorry for late response. Did this many times on all types of cars and trucks.
                  • Rod K.
                    • 443
                    If the above suggestions are unsuccessful you could always just remove the drum and hub as an assembly (remove spindle nut) to get better access on the bench.
