Are My Shocks Bad? - NCRS Discussion Boards
Are My Shocks Bad?
+ More Options
Posts
  • Michael C.
    • January 9, 2013
    • 332
    Are My Shocks Bad?
    I've installed rebuilt trailing arms on my 69. I'm wondering if I should replace the rear shocks. They're old Delco "Gas Cushioned." I read somewhere that shocks are bad if they don't extend back if manually compressed. Is that correct? I can compress mine with some force, but they don't extend back unless I pull on them. Requires some force to extend manually. Are mine bad? When everything was assembled the rear end didn't bounce when I pushed on it.
    Thanks, Mike
  • Michael G.
    • March 2, 2008
    • 485
    Re: Are My Shocks Bad?
    Gas charged shocks would rebound. By you description, Your shocks are functioning. No leaks?
    • Michael C.
      • January 9, 2013
      • 332
        • 15706
        High pressure shocks, otherwise known a deCarbon type, like Bilsteins, will always expand to full length due to the high gas pressure if not otherwise constrained.
        I have no idea what "gas cushioned" means, but it's likely just marketing nonsense.
        If the shocks aren't leaking and the rear isn't bouncing all over then they are likely okay.
        • Michael C.
          • January 9, 2013
          • 332
          Thanks for the replies. At this point, I'm ready to get this project done. The shocks are easy enough to replace later...if needed.
